breakstuff
Will later A body tie rod ends work on an early A? I'm using later spindles but my main concern is will they fit into the drag link.
us C-body ends, theyre less expensive, and 11/16 compared to 5/8. you will need the adjuster sleeves as well. the tapered snouts are the same and should fit like butter. Im doing this on my 66.
If it was a rough service vehicle like a truck or if I drove on ice/snow and thought I might slide into a curb.
Before 68 when the idler arm was mounted in 1 weak little ear. That is where the stress was disapated ( What wasn't releived in the steering gear box anyway ). A good bang on the steering linkage did often mean go get the toe reset. Rarely would anyone bend a tie rod end though.
Actually, the stress still went to the same places in 68 up but that idler arm is better designed to absorb the stress.
