Tie Rod ends?
BJDEALER
New Mexico
Ok I have just about completed my brake disc swap on my 66 cuda. I had a 74 swinger parts car which is no longer available mind you. I have brand new brakes on the spindles ready to put tie rod ends on and the ends on the original suspension will not fit in the hole on the 74 disc spindles? They worked just fine my stock 9" drum ones. I did change the tie rods when I put the v8 center link in. Can anyone enlighten me here?
Ok I found out that the tie rod ends are different part #s for the 2 cars. How come nobody has this problem?
NEVERMIND! I FOUND A THREAD THAT EXPLAINED THIS.
