Time marks
Aspen79
Texas
are the timing mark on the timing chain cover on the same side for 318 and 360 or do the use different covers?
Depends on what year.........about 69 or so changed, different balancer, timing cover, and water pump. "Early" had timing marks on pass side, lower water pump fitting on driver side. "Later" switched.
318/ 360 use different WEIGHTED balancers, but marks / timing cover are same in same year range. If you switch all three pieces you can change them from early to late, or opposite
1969 and older 318 and 340 = timing on passenger side. 1970 and newer 318 and 340 and all 360 = driver side
