1DUSTER360
Go Car
So the timing chain cover seal for the harmonic damper shaft is leaking oil. I have managed to pull the damper and wonder if I can now just pull the seal out from the timing chain cover front without pulling the cover? I do not remember if this seal was installed from the backside does anyone know?
Do I need to pull the waterpump as well as the timing chain cover and maybe drop the oil pan? The engine is a 1997/360. It is hard to tell by looking at it as the motor is in the car.
Thank you for your reply.
