Timing degree
65 CUDA
PHOENIX,AZ
What is the timing degree on a freshly rebuilt 318 with rv cam, bored .30 over on pistons holley 600 cfm 4 barrel on a 1975 motor
I would start with maybe 8-10 BTC. Depends on the curve in your distributor. You may need or want to recurve it for a shorter curve.
probably around 14-17 initial , 34-36 full mechanical advance and 50-54 cruise vacuum
I have it at 28° with a vacuum advance distributor
Probably a little much.....unless you're using full manifold vacuum on the vacuum advance. We can get you closer if you post the cam "SPECS" instead of "RV cam". If that's all we have, your answers will be just as vague. Hit and miss.
I have vacuum hose plugged into the port on holley 600cfm carb at right top side of front fuel bowl going to vacuum advance on distributor
200° - 215° duration based on .050 cam lift
You sure that's not 204 and 214? ....and I assume it's on a 112 LSA? This works a lot better if you supply all the information.
Advertised Exhaust Duration288
Advertised Intake Duration278
Cam TypeHydraulic
Computer Controlled CompatibleYes
Exhaust Duration at .050 inch Lift214
Exhaust Valve Lift0.443"
Intake Duration at .050 Inch Lift204
Intake Valve Lift0.421"
Lifter TypeHydraulic
Lobe Separation112
Cam TypeHydraulic
Lobe Separation112
That's a very decent grind for a street engine. That's what I thought it might be.
That sounds like the right spot. Ported vacuum. I would recommend that for a very mild engine like this. I would back it down to maybe 18 degrees initial and see how it performs.
65 Cuda,
[1] Warm up the engine
[2] put in gear if auto & chock the wheels
[3] loosen dist clamp & turn the dist SLOWLY CCW. That advances the timing.
[4] Keep going CCW until you have the highest idle rpm.
[5] Now check the timing. It will be well over 20 & could be over 30*.
[6] What ever it is, that is the best idle timing for THAT combo & you get that by using manifold connected vac adv.
All the people below are not wrong...or imagining things...
