Found a place out of Ohio called Hub Bearing; you can find them @ hubbearing.com . The axle set for our 8 3/4 are $27.94 or $27.99 each. The Timken part number is 'Set 7.' The axle seals are under $2.00 each- the only place here that even knew what I was talking about was NAPA and they wanted $44.99 each plus tax (8.9% here)- Orders over $50 ship free from Hub Bearing!:cheers:
