cidVicious
Junior Member
Hey A Body Experts,
I need a little help here on tips and tricks for aligning and bolting up a 727 to a 360 in an a body. For those of you who have done this before, I'm sure you know that there is very limited space for algining the transmission and getting the guide pins to slip in enough to get a few bolts in and sink up the transmission.
This engine/transmission combo came out of the same vehicle, so they were together when I got them but I pulled them appart for cleanup and installation. My 360 is in the engine bay, and the 727 is in the trans tunnel. Motor mounts have not been tightended so I can move the block around a bit. It also has headers installed (tight fit, ugh!); however, they are not tightend either, so there is a little wiggle room.
I can get the tranny moved up to within about 2 inches of the motor, but then I'm having trouble getting it to go any further. Alignment seems to be a bit off. Can any of you seasoned mechanics offer any tips or tricks on how to ease the transmission up to connect with the motor? Any help would be greatly appreciated.
Thanks,
Thanks,
