Tires and wheels
chodge
Member
Brandon
This is my 1967 Valiant. Cop wheels. 15x7 BFGs 215 60R 15 4.5" backspace in front. The back has Mickey Thompson sportsman SR. 15x10 5.5 inch backspace. Just finished my mini tub project.
Nice car, I'm building one of these myself. I like those 68 tail lights too.
Looks great, how did you do your minitub with a kit or from scratch? How much did you shorten your rear? i am thinking about doing this over the winter I am looking at the cartool kit.
Nice, post pictures of your mini tubs.
This is mini tub is a
car tools kit. As you can see I made a new trunk floor. I put in a different gas tank. I went with a different gas tank so I could run tailpipes after the minitubes.The rearend is a 9 inch Ford with a custom width.
are the rear frame rails in the stock location?
did you go with a larger than stock gas tank?
The frame rails are in the stock location. The tank I put in a 15 gallon tank. It is a 57 chevy tank. I am sure many will disapprove, but it has its advantages with minitub. Its sending unit is in the front like a stock one. Plus its narrower so u can get tailpipes through. The tailpipes will be done later in the week if want a pic.
