Some friends and I have been talking about titles on cars would have a place on the paper work to check off if it was a rebody or not. What does rebody mean?
Legally,(in Cali anyway.) A re-body calls for an existing collision /body shop,to swap bodies legally,under a owner registered VIN.Anything else,falls in grey area.Carroll Shelby,and Boyd Coddington got popped for this.Be careful.
I don't plan on doing this. But it came up as a topic. My 2 cents it was illegal
This topic is just about as old as the automobile industry.In Missouri if you use a fender/hood/seat/engine etc from a salvaged vehicle to reconstruct another you must hold a photocopy of the original title of the salvaged parts vehicle.Is this law used? Only in the cases of stolen property.Illegal to rebody-yes,how many rebodies are on the road? I don't know.The point is,if you have used parts from another vehicle on your car and you don't hold a photocopy of the original title from the donor vehicle you are just as illegal.Remember when you point a finger at others-lots of fingers are pointing at you.
So a simple reading of post # 9 above shows that if you intend "to further the theft of a motor vehicle" you are breaking the law and if caught you will be fined or imprisoned under this law, but "if that person [who wants to remove, obliterate, tamper with or alter the decal or device] is the owner of the motor vehicle" he can legally do it.
Obviously the intent of the law is to prevent any theft of an automobile but not prevent a law abiding citizen who legally owns a motor vehicle from restoring his damaged automobile, if "the removal, obliteration, tampering, or alteration is reasonably necessary for the repair."
For example a car is T boned at the area of the left cowl crushing the left windshield pillar, upper left cowl, left front fender and the dash board which contains the VIN number. The above law implies that he can legally remove the VIN plate and install it on the new dash pad because he legally owns the vehicle, is not stealing it, and he needs to do it to repair the vehicle. He can also transfer this authority to "his authorized agent." An authorized agent could be an automobile body shop or automotive restoration facility.
Scenerio # 1. You have a 1969 Dodge Charger with a 426 hemi engine that is a total rust bucket, but after referring to an AMD catalog you feel the car can be repaired if you use their 25 aftermarket body panels that were stamped in China and also a used cowl from the wrecking yard. Is this a 1969 Dodge Charger manufactured by Chrysler Corporation or a hand built 1969 Dodge Charger built by a body shop that still has four original body panels that came from Detroit, one of which is not even original to that particular car but it is a Chrysler built part.
Scenerio # 2 Same car as above but you want to restore it with "real" 1969 Chrysler Corporation steel so you find a 1969 Dodge Charger with a 318 V8 that is in pristine condition. You buy it and you swap the engine, transmission, differential, fender tag, VIN tag, from the hemi powered car, into the 318 car. You stamp the radiator support and the left rain gutter with the correct numbers from the hemi powered car to complete the transformation of the 318 car. You then buy the two reinforcement panels from AMD that are needed to box in the rear spring areas and you have the car stripped of its paint, the dents are fixed and the car is painted with the color stamped on the fender tag. Is this a real 1969 Dodge Charger?
Are both cars fakes? Is one real and the other a fake? Which one?
Benji
Number 1 is a real car. It was built that way at the factory. Number 2 is a fake, always will be a fake. If the car is too far gone to restore it, removing the vin and putting it onto a another body is wrong for this hobby.I won't even talk about whats legal. Now if you don't agreed with me that's cool, but ponder this. You go to big time auction and drop 75k on the dream car you always wanted.[
Benji
a few months later you find out somehow that this is not a "AAR Cuda", but was a 6 cyl. car. Paperwork with car,fender tag and Vin match AAR.
Are you like" That's Cool, still an AAR.....
Because s@#t happens. When my friend Jim went to cut my dash for the cage he removed the vin tag because it looked like it was going to be right where he had to cut. Ended up being safe by an 1/8".....of course the one replacement rivet was not done correctly and not holding anything.....I have a "collector" friend, more like hoarder that bought an original z-28 that had been shoddily converted to a race car decades ago. He removed the vin's from the car and listed them on ebay......think his brother ended up getting busted for it as last registered owner of the car was his brother and the ebay account was his also.....if it is illegal, then why are original dash VIN tag rivets legal.
Because s@#t happens. When my friend Jim went to cut my dash for the cage he removed the vin tag because it looked like it was going to be right where he had to cut. Ended up being safe by an 1/8".....of course the one replacement rivet was not done correctly and not holding anything......
Cliff, sorry for misleading you. I don't think there will be an issue in my case. I do plan on replacing the loose rivet at some point. The vin on my dash is the original one to the car, matches the title. The guy that got busted was selling the tags/vinned parts off of a cr on EBay to someone that was going to attach them to what was NOT an original z28, in essence a "rebody". Just to throw something else out there, my chopper has a state assigned vin. I bought it as a "bike in a box". Bought the documentation, think they were called MCO'S, down to dmv and they issued me a vin number. Every state will be different obviously on this stuff. In AZ you could apply for an abandoned vehicle title if someone left a vehicle on your property. Up here in Washington, from what I have been told, there is no such thing. My neighbor was storing some cars for a few different people. These people are either dead or in jail now. These folks families had no idea where the titles were. Jim called dmv and was told that he needed to contact the State Patrol. They will come out and get the vins and spend 30 days looking for the last registered owner. If not found, the State Patrol will then dispatch a wrecker and remove the vehicle, sending it to a scrap yard. In AZ if this happened, dmv would spend a month or so looking for the last registered owner. If they could not be located and the vin was not reported as stolen dmv would then issue you an abandoned vehicle title. If at that point the previous owner were to reappear he has no rights to the vehicle, as I understand it....Ink are you saying if you take a vin off to do work on your car and replace it poorly you can still get busted for it?
Have a friend that worked in a shop for years. When we were walking around MATS this year we walked by a 70, I think it was, convertible Hemi Cuda. Car was a former SS record holder in whatever class it was raced in . My buddy was telling me that when he tore into the car it was so twisted up from being a racer the rear half was beyond being salvaged. He proceeded to cut the car in two and replaced the rear half of it with a car that he had in his yard that he was going to build "someday". He had told me that there were very few cars that he had touched over the years that were "original". He told me that in the 80's-early 90's the practice of piecing a muscle car together was pretty common in every shop he was associated with. Glad I am not a #'s guy. /6, 3 on the tree was a perfect starting point for me. Car would have taken 4x5 times it's value to restore it. That is why when I was getting grief over a gm trans I just could do nothing but laugh. Someone told me they thought I was one of the biggest pr*&k's on the planet for cutting up the floor the way I did. Oh well.......
Legal? Damn good question. I think everyone has there own opinion. I don't look it at as legal/illegal but more of a question of morals. And when it comes to money, which is what some of these cars and there owners are about morals are often cast aside. Same friend that was trying to sell the Z28 tags was trying to pass off a Cutlass as numbers matching bb/stick shift car. Don't remember all the details but when he was selling it he had a guy on the hook for it. Guy was going over the car very carefully. Some how he traced the car back to ones of it's previous owners who told him that it was not what it appeared to be, that while it did have all the correct parts to what the vin claimed it to be it was because he had taken all of the parts from an original bb/stick car and moved them to a 350/auto car. When the previous owner had sold the car he claims he never tried to pass it off as something it was not, going as far as having a copy of one of the magazines it was listed in. Like I said earlier, glad I am not a numbers guy.I think your car came out great no matter what parts you used it is your car to do with as you please. But I didn't know body shops doing this was common practice back then. Being that was a controlled environment was it legal?
