68gts340
these guys on here have given you some real great ideas and suggestions, probably the best that you could buy, and it is for free. I feel a need to try a diffferent approach. it wont be very popular though.. but it needs saying . ...
it is my opinion (fwiw ) to start out a little slower, their is so much more you need to learn. this is only a suggestion , but here it goes...get your 3.91 s and the 8 3/4.. get the drive shaft too if you can ,you will need it. install only the rear and , now take the car to the track , and run it , learn how to read the tree ,stage the car ,see just how long a .750 reaction time is, in other words learn how to drag race, safely and legal... and have fun most of all. this is what it is really all about....
next dial in the car ...see if you can make it faster with what it has, try different timing settings ,different carb settings , even set your pinion angle . but here is the key....do only one thing at a time.....this is very important for a simle reason, it the car runs worse then you have learned what not to do, and becuase you only changed the one thing ,you can put it back with out trying a dozen different things .. then put on your next bolt on item . maybe the headers.. and run the car some more ...try different settings again, next put on your carb,, and run ...and try to fine tune and so on ......untill you have all that you can get out of the chassis and the bolt ons......NOW YOU ARE READY TO ADD A BIG MOTOR.....you will be able to drive it and tune it ... and you will have learned what changes do what to a race car.... now you have arrived... you know what is wrong , know where to look and how to fix it... and above everything else your pride and joy new motor will be in one piece ....to many of us have wasted new motors for dumb reasons..I. E . never have heard detonation before,,,whats that noise ...huummm cant find it.....run er again.....BANG....smoke ...oil.... tears....took out a piston....
like I said ..only my opinon... but most of us can only afford one motor...
start building your motor that you want ,just have the car and the driver ready , BEFORE you swap her in there....THEN go kick some a$$....
I welcome any ones opinion on this .... Ron
