Sorry but . . .I did not make Famosa nor The Spring Fling or find a suitable car for Dan or is '64 Dart running yet.
Spring snowmelt coming and fire/brush clearance deadline June 1st. The Echo weedeater string aftermarket auto spool ran out at dark so figured I'll run cheap blower a bit. After yanking on it a bitt maybe I'll get that started manana after wearing myself out tonight, lmao.
No problemo I'll blow underneath car/ garage and pollen etc. on driveway with compressor/Harbor Freight. Naturally for the 1st time no go, huh, wow and now I'm PO'd.
YouTube a troubleshoot video, remove shroud, push button for breaker and still no go. OK you get what you pay for.
As I have Zero patience and am on borderline meeting The Reaper or not, I'm thinking Faaaaak.
Long story short LMAO, I hit the box/housing for the brass/lever/switch with the handle of a screwdriver a couple times, flipped the the switch and bingo bongo I'm a genius as fired right up.
I can hardly wait for tomorrow as the unexpected always seems to arise.
If The God Durned Reaper shows, a hammer, screwdriver, wrench, rock, ax/jack handle or whatever might suffice to postpone that scenario with any luck.
Patience is a virtue but sometimes it wears a bit thin. Be careful as always.
