open the relay and polish the breaker contacts with 400 or higher grid. Ohm resistans shoul be lower than 0.5 ohm!
You can measure the voltage drop at the starter relais. Should be less than 0.5V. Voltmeter to connector Bat relais and Starter out at relais. I bet yours read around 2V! Parallel voltage measuring is the fastest way to diagnose. Voltmeter Batterie plus to starter connector should be as low as possible 1- 0.5V or less. Same ground from battery to engine/starter ground.
Bad connectors create always excessive heat.
