10mi or so.
thats nothing really. but if you dont change the fluid and stop the coolant from getting into the trans fluid, it will stop working. even if you can replace 4 or 5 quarts of it , and stop the coolant, you will be strides ahead of a permanent failure....IMO
ok so just connect the lines together at the rad...drain the trans, flush the rad and block the holes, then refill the trans?
if D5667 can help with a radiator , i have one for sale here that you can have for shipping $
Ill have to see what I can do. Right now bills are due and i dont know if Ill have any cash until next week. this goofy thing always seems to go nutty in between checks.
i hear you there, thats the story of my life LOL. i would just send it out to you , but im broke until next tuesday :violent1:
at least stop the coolant into the trans fluid and get a few quarts of new into it. it should last another week.
I just bought a new gal of trans fluid last night..thats when I found out that I was geting water in the trans. I was supposed to be at a small charity carshow/cruise sunday. If I get the trans cooler up here and change out the fluid..will it last a 5mi or so drive?
Well apparently my trans cooler is MIA. Just got off the phone with grandpa. This day keeps getting better
just connect the lines together and get another radiator
D5667 has one and i have one. you might hit him up first because hes closer and 1st in line
kk sounds good
JR, I haven't been on here for a few days and just saw this thread. I'm located a couple for hours east of Springfield.
Sounds like cascius has you covered on the cooler. If not, I should have one laying around here somewhere, finding it is the problem. lol
I've seen quite a few trans that had water in them still work for a long time after they were flushed out.
PM me if you need anything as I'm not on here very day. I'll help if I can. I have lots of parts, including /6 trans.
Good luck,
Dallas
Someone correct me if i,m wrong. Seems the trans is vented and they run between 140 and 220 according to load and ambient temp. If you got 90% of the water out wouldnt the remaining moisture turn to vapor and vent out?
