moparduster
Ok heres the deal... I acquired and LA360 short block stock stroke, factory rods, 10.5:1 .60 over pistons. If I put a stroker crank in it that can only help. RIGHT? also what else would I have to do? (machine work, etc?) Im gonna be running RHS heads, Mopar purple shaft .320 with .533 lift cam, M1 with holley 750DP, 727 manuel valve body, 3800 turbo action converter, 8.75 with 4.56 on a spool, 29X10.50-15 hoosiers. Also what kinda numbers should I be looking at with this set-up?
