flathead31coupe
supercharged bb. fender well type headers ceramic coated inside and out, currently without running a hood it doesnt over heat, will running a hood with it cut out for the supercharger make it run hot?
kinda what i was thinking..plus the hole in the hood may help to let heat out...Impossible to say, but note that by running without a hood, the fan is not necessarily effective at pulling air through the radiator — the air can much more easily just go over the top. The hood will tend to trap ambient heat, so the question is can the water pump and radiator remove heat fast enough? The supercharger itself will still be up in the airstream, and the fenderwell openings will provide a certain amount of exit capacity for hot air once the hood is in place. The only way to know would be to test it, perhaps with a jerry-rigged plywood hood.
