Tons Of Mopar Parts!!!
72 340 DUSTER
Northern Kentucky
Rating - 0%
0   0   0
I am cleaning house for winter and all of this, yes all of this must go! heres the list! thanks
duster, dartsport, demon complete clear glass minus windsheild-$200
Black Kick Panels, orig Nice-$30
Upper metal headliner hold down peices blue-$10
Sill Plates orig Nice-$30
New Milodon Windage tray 340-$40
New Crane Valve springs good to .525 lift-$75
Double Roller timing chain orig 340-$15
late 71 340 rods and pistons-$125
318 rods and pistons hd-$50
67-72 abody centerlink, blasted and painted-$25
73-up lower control arms rust free-$100
73-74 duster grille nice-$50
73-up bumper-to-grille metal filler rust free-$25
904 duster driveshaft-$30
73-up front lock support assembley-$25
Bumper jack assembley-$30
Duster, demon, dartsport fuel filler neck-$20
Single groove water pump and crank pulley rust free-$30
New Moog Idler Arm 67-72 A body-$25
New Moog Pitman Arm 67-72 A body-$25
A/C under dash vents nice-$20
New Rear Sump BB Mopar Performance Oil Pan and pic up-$75
A-body glove box door w woodgrain-$15
Blue stnd 3 spoke steering wheel and center cap nice-$40
Black steering wheel with large 3 spoke center-$25
Column shift steering collumn parts, everything except shaft-$50
68 barracuda floor shift collumn complete but apart-$100
68 barracuda black standard steering wheel, very nice-$100
74 A-body front bench seat white needs recovered-$35
74 abody battery tray-$10
340 oil pan pic up factory-$10
Big Block 73 Exhaust manifold, baffles have been removed and welded, sandblasted, port and polished, then proffesionaly sprayed w a cast iron appearing temperature paint-$300
Thanks for looking, all prices are negotialble and shipping will be as cheap as possible. Please send me a pm if interestead in any parts, i will give excellent deals if you buy a bulk of parts, thanks
part numbers on the moog idler & pitman stuff? thanks Lawrence
could you send me a pic of the black steering wheel and the 73-74 grille? What year is steering wheel out of?
Thanks.
"New Moog Idler Arm 67-72 A body-$25
New Moog Pitman Arm 67-72 A body-$25"
You might want to recheck. The 67 idler is a one year only deal. Don't know about the pitman
Do you have any column shift linkage parts? I need the lower rod that goes from the shifting linkage to the lever on the transmission.
anyone heard from this add? I've pm'd 2 x for the moog part #'s no response.
