rdakota340
Has anyone ever had this happen and eat up thrust bearing and crank. I put 300 miles on the car and the scat crank is junk, the motor is apart and you can clearly see the crank was pushed forward all of the clearances have been checked on the converter and flex plate. The converter has not ballooned that was checked also. the only lift is a cooler restriction.
