holly street avanger carb eddy heads 60779 hartland rocker are eddy rpm intake 340 is 30 over cam purple 287/523 lift soild lifters is this a good top end looking for some answer before i buy
If you are using a stock piston or a TRW replacement piston, you are going to want Edelbrock 60179 head to clear the raised quench pad on those pistons.
The early higher compression 340's had pistons that were proud of the deck. Spec was .018" over the deck, but obviously that depends a bit on the engine with factory tolerances. Makes running a closed chamber head interesting for piston/valve clearance. You can run a thicker head gasket, but obviously that has its issues too.
