I haven't found any thread discussing proper torque converter bolts for performance converters so I'll ask it here. Using the usual B&M SFI flexplate (#10230) that is 0.150" thick, what torque converter bolts do you use for a converter that has the 7/16"-20 bolt holes? The ARP#240-7302 bolt shows the underhead bolt length at 0.500" so that would mean there is only 0.350" of thread (0.500-0.150=0.350") into the converter lug. That doesn't seem like enough for a 7/16" bolt. I don't see anything listed for other bolts in the 5/8" length range.
ATI sent bolts with their 8" Treemaster converter but they have washers that make the head too thick and they then kiss the block. I called ATI and was told just not to use the washers but with the small hex head, it doesn't seem to cover as much clamp area as the more rounded-head 12-pt ARP bolts. These ATI bolts are, however, 5/8" long in underhead length so that part would be much better with about 0.475" thread engagement.
Thx for the help - I'm sure many of you have been down this road already and know the solution!
