Rbob
Must be old / tired / zzzz.....
FYI My car has the 73-76 K-member / disc brake / Big upper ball joints.
The two I have trouble figuring out is
1. The upper caliper bracket to the (knuckle) spindle torque.
2. The lower ball joint bolt/nut to (knuckle) spindle torque.
upper ball joint nut................55
lower ball joint nut................100
lower control arm pivot nut.....145
control arm upper cam bolt.....65
rebound stop nuts.................25
crossmember bolts................150
idler arm mounting nuts...........45
shock absorber lower mounting....50
shock absorber upper mounting....25
steering knuckle bolts (lower)....100 *****
steering knuckle bolts (upper).....55 *****
drag strut nut (front)...............40
drag strut nut (rear)................110
anti sway bar nuts...................30
tie-rod end ball joint nuts..........40
tie-rod end clamp pinch bolts......15
steering box mounting bolts......100
pitman arm nut.......................175
I am guessing the ones that I put ***** after.
Sound right???
Sound right???
