Torqueflight Identification
sean
Boise Idaho
I have this Torqueflight and I don't know what it came out of. The starter mounts are on the passenger side. I don't mean to seem dumb, does anybody know what its for (Industrial purposes?) Thanks
AMC possibly? Starter is on the wrong side for a mopar.
AMC might be a good guess. The starter mount isn't Mopar-spec; probably meant for use with a side-mount Delco (GM) starter. Check the driver side of the housing, just above the oil pan, and see if you find any numbers stamped there.
Don't forget Intercrashanational, er, I mean Corn national Interbinder, otherwise know as Farmall
http://www.ihonlynorth.com/forums/transmission-tech/588-torqueflite-727-guapo.html
Thanks Everyone! Thats one less thing I need to wonder about. Now all I need is a Boat to go with this Anchor!
