Torsion bar compliment to 340 XHD Spring
Wvbuzzmaster
West Virginia
Kind of an interesting question that got me thinking. I had upgraded my rear leaf springs to Espo 6 leaf (340 XHD) which have a spring rate of 130 lb. I understand that Torsion bars should compliment the leaf springs, so on a car such as a V8 Duster, what is the correct compliment torsion bar up front. I already bought the PST 1.03” bars which have a rate of 230 lb in., but figured I would ask the question, it could benefit others going this route, or I could be off in my selection of parts myself. I know the consensus is that 1” minimum bars really should have come from the factory and no one has been sorry they upgraded their torsion bars either. How does one determine how much spring rate they need for just an average well mannered car that is just a street car, and not a full fledged drag or auto cross car?
I have 1.06 bars (252 lb/in WR) and the same springs in my Duster (stock height). I think it drives quite well and you should be happy with yours also. I live in Michigan and in my opinion it rides fine, similar to a 2011 Mustang GT. That alone will make a big difference in handling because the front of these things always had too low of a spring rate.
What are you running for wheel/tire size? 15's will be a lot softer than 18's for the ride and the steering response is reduced. You get slightly more bounce with more sidewall.
Make sure you have good shocks like the Bilstein, Koni or Hotchkis/Fox ones. If you run regular old parts store shocks it won't dampen it that well.
Along with larger torsion bars a 1-1/8 front and 3/4 or 7/8" rear sway bar goal long way towards handling. Just know stiffer springs make for a rougher ride we're sway bars typically do not affect ride quality. What ever you do buy some good (i.e. Bilstein, Viking, Hotchkis, Fox, Koni, etc.) shocks to control the springs.
I am running 15” wheels all around with 215/65r15 on 15x7 up front and 255/60r15 on 15x8 out back. I have purchased a lot of parts for my Duster already and Billsteins are on the want list, but going to wait til I get more of the car together. I will be putting a sway bar on the front for sure, probably not on the back though. My rear leaves are +2 cause I wanted very noticeable rake. I also understand the good shocks rule, and not cheapening out on the car already, just starting to be selective about buying more parts until I get the rest of the parts I bought bolted to the car. I still have to redo dash, wiring, interior, and brakes... minimum, scope creep took me into suspension due to in the area... oops lol.
There are formulas to calculate that kind of stuff, but they require you knowing the corner weights and front/rear bias of your car. Among other things. They're more intended for race cars, and even then they're just a ball park. The wheel rate requirements change on the corner weights, rake, tire width's and compound, brakes, wheel alignment settings, driving style etc. Heck the road race guys will change all of that stuff from one track to the next and depending on the weather and air temperatures.
I run 1.12" torsion bars on the front of my Duster, with a 1.25" hollow Hellwig bar up front and 121 lb/in AFCO rear springs with a 7/8" rear sway bar. I feel the car is pretty well balanced, but I also have a tire stagger with 275/35/18's up front and 295/35/18's out back. And I'm down to a 200 treadwear tire. With a 400+ treadwear tire like you get with most non-race 15" tires my set up is probably a bit too stiff. But it also might be a little soft for 80 treadwear race slicks. All relative.
With 130 lb/in rear springs I would say you should be fine with the 1.03's and sway bars, you may end up "tire limited" with that set up so you may get some oversteer. That would be the thing with stiffer rear springs, you may end up too stiff in the back and get oversteer with the sway bar. The rear Hellwig sway bar is adjustable though. Just as a general recommendation for street use I'd say anything from 1" torsion bars to 1.06" torsion bars would be fine. Clearly I went larger than that, but I have wider and stickier tires too.
1.03 bars will be fine. stick a sway bar on the ***** too and you'll be real happy. i'm running 1" bars with a hellwig front sway bar. and eaton 130 pound rear springs and it feels great on the street. does everything i wanted it to do.
Great question and answers. I have a pair of Mopar Performance 1.14 torsion bars going on the front of my '69 cuda and will probably go with a bit heavier front sway bar replacement. Not sure about rear springs yet but not going with a rear sway bar.
