Torsion bar question.
Cuprum-74
Moparus Fanaticus
Utah
Well I finally decided to change out my lower control arm bushings and ball joints.
After 2 1/2 hours on the driver side I got it done. The LCA bushing on that side was shot there was only about a 1 inch by 2 inch piece of rubber left, as well as about a handful of rubber powder.
Now I figure I can now do the passenger side in less than half the time.
These things are scary simple! This is the first time I have done any major suspension work. (putting lift kits on jeeps don't count)
Now for the question:
I went ahead and measured the torsion bar. It is at almost 13/16 of an inch (or .8125) so I am guessing .81.
Someone here in town claimed that he has a .85 torsion bar he can sell me.
It Sounds like a good deal but a local mopar guru told me there is no such size and that I should just save my money and buy the bigger ones. (he said .89+)
So would the .81 bar suffice for a high performance 360 mated to an A999 and street 3.23 gears (soon to be 3.55) until the dreaded tax season is over? Or should I replace them before they break? (if they can break)
This a 1974 Plymouth duster by the way. The motor is a 1990 360cu and has 9.7:1 compression with Speed-pro flat-top pistons, 308 heads and Hyd. roller cam at 291/311 dur. and .522/.509 lift.
It also has an upgraded valvetrain, air gap manifold and A999 tranny with TF2 kit in it.
PS. I also have KYB gas-a-just shocks, with the bigger bars I'm thinking it is going to ride like a tank. Bilsteins is another thing for me to get I guess.
I ran 920's for ten years before upgrading to 1.06 inches. The 920's gave a soft ride. Unless you are trying to transfer weight while launching I would go with at least the 890's.
I posted last weekend that my torsion bar measured .855. I have a 66 Dart that had a 273 from the factory. nm9stheham posted a chart in my post that listed the .850 as a 110 lb/in spring rate. It was used in the 6 cy with AC & 318 no AC cars.
http://www.hotrodreference.com/90/mopar-a-body-torsion-bar-size-and-part-number-reference/
That was the first time I saw this size listed anywhere.
As for do they break, When I was younger working for my dad in his garage in the 70's I can remember only ever replacing 3 torsion bars. When they break I remember the bodies hanging all but on the ground. We had to use jacks to get them up on the lift. We worked on many dodge / chryslers as dad spent many years at a dealership but I only remember doing 3 of them.
Rod
Well I went out and remeasured. (stupid sway bar measuring tape was useless).
The circumference is about 2 3/4 so that puts the diameter at about 7/8.
conversion to decimal would put them at 2.75 = .875
So I have .870 bars. I am probably going to upgrade between .920 or as high as 1+ inch later.
