yellowghost
Is there any significance to the slots on the torsion bars as far as positioning goes? I got everything back together and the drivers side sits about an inch higher even thought the adjusting bolt is screwed in farther than the drivers side. I did not make note of the slots when I took the passenger side, only made note of what end goes to the control arm. I diagrammed the slots when I took out the drivers side, the slot in the frame end of the control arm was verticle, but stupid me, did not realize that slot can be verticle in two different positions. The mechanic who installed the bushings seemed to think they were the original bushings so if so, the torsion bars might never have been removed, so if the factory installed them all in a certain way, we might be able to know exactly what position they were in before.
Thanks
Jeff
Thanks
Jeff
