I think torsion bars are way easier to disassemble and put back together. Maybe I am missing something, but reinstalling those coil springs is a two man job, and you can set the preload on torsion bars to establish your preferred ride height.
It so is not a two man job. You just gotta be smart about it. A pair of jack stands and a floor jack is pretty much all I use. There are exceptions of course, but it really is no more involved than a T-bar, just different. Like RRR said, they both have their pluses and minuses.
I would like to see one person do it on my suburban. I have been working on cars for 35 years pretty by myself and I know almost every trick in the book to do things by myself. To get the coil spring started, I had to give a good push with my foot on the bottom of the spring to get it in the back of the lower control arm receiving cup and I had my son starting jacking away.
I am going to give you the benefit of the doubt and assume you are not saying I am stupid..
I am rebuilding my brand X Suburban front suspension. I will take torsion bars over coil springs any day!!!
??WHAAZT? Another ..........
My brand x Suburban has torsion bars. 2001 model. Maybe brand x saw the light!
Oh dear lord, I would never call you stupid, dumba$$.
Rusty is pretty on with it. I usually pull the rotor and backing plate on the Chevy trucks so I can get directly under the lower ball joint and make sure the floor jack is straight with the motion of the control arm. (90 degrees to the vehicle). I also have a couple of big prybars to help wrangle them suckers into the pocket.
Or, you can use a 5/8 piece of allthread, some washers, nuts and some flat steel plate with a hole in it. Completely drop the lower arm, drop the allthread through the shock hole with a washer and double nuts on top. Install the spring, the lower arm, the steel plate, a washer and a nut. Keep some lube on the allthread, hold the top double nuts and tighten the lower nut. Takes some time, but will spin that arm and spring right up into place.
I think pushing in the bottom of the coil spring with my foot and then having my son jack the lower control arm worked pretty good. I still think it would a PITA by myself...
