Cameron1038
Hello folks,
I bought a carter afb for cheap and im trying to get some more info on it.
Here is what i know:
There is no part number on the mounting tab, and no steel tag.
It says carter afb on the front driver side.
It says made in usa on front pass side.
It has a 4 5/8" air horn.
The bore diameters are 1 7/16" and 1 11/16". I have read that this makes it a 500 cfm.. not entirely sure.
It has the # 1694 cast on the top driver side.
It has 0 - 1565 cast on the pass side behind the linkage.
It has 450 cast into the bottom under the choke.
Well, thats all i know!
What i need to know is a part # for a rebuild kit and/or what this carb came on originally. And if you can verify that it is a 500 cfm.
Thank you so much!
Cameron
Thank you so much!
Cameron
