Towing with a Duster.
All towing package cars got an upgraded rear axle. If the car had a 7 1/4" axle standard, the upgrade was the 8 3/4" axle through 1972. The 1973-76 A body trailer package cars got the 8 1/4" axle.
At junkyards, I've seen two separate 70-71 4 door Darts with slant sixes and 8 3/4" axles, cars that had no reason to have a high performance axle except for the towing option.
Would it be possible to safely tow a Duster with another Duster? I am thinking about super light 16' open trailer, possibly even custom made to get the tongue weight as light as possible while still following the tow vehicle without flailing around.
Thinking it would be fun to tow my race car with my street car. Short trips like 35 miles to the track, or 15 miles to Cars & Coffee type events.
Has anyone done this?
Cley
View attachment 1716435869View attachment 1716435870
Car looks great! Mind sharing rear leaf springs? Love the stance. I'm in search of springs for my dart sport. I want the stance your car has!
Just the ole "Hecho en Mexico" Super stock springs I got from a Dodge dealer 20 years ago. They have stood the test of time!
Cley
Did you put the left and right or just both left or right to be even? 2800 lb leafs or 3000 or 3800lb? Thanks
I put the left and right on the correct sides. They are the heavier 3200lb springs if memory serves. 002,003 at the end of the psrt numbers.
Cley
Wow, I didn't know that in Canada. you'd need a 10k pound vehicle to tow 5k pounds!
You don't. The maximum total weight one can tow with a regular operators license is 22,500 lbs. This is total weight of tow vehicle, trailer, passengers, cargo, everything included. The trailer cannot exceed 4600 kgs which I believe is 10,000 lbs. That is trailer plus contents (GVW).
I used to regularly tow a 16' ski boat full of camping gear over the Coquihalla Highway, no drama.
The cops may check your vehicles tow weight, here, trailer and load can't be more than 1/2 tow vehicle weight.
Good luck, looks cool.
It won’t legally fly here Cley as you car and trailer will weigh more than the tow vehical. Check out the rules and regulations from SGI. Kim
Here in Saskatchewan u need to upgrade your regular drivers license to tow anything over 10,000 pounds. That’s the combined weight of the tow vehical, trailer and whatever your towing. Also u have to up the combined weight to the total weight and u pay extra for that. Kim
Although my brother and I towed my 67 dart gt from Flin Flon,Manitoba to Unity,Saskatchewan with a tow rope. Total of about 650 miles all in one day. This was in 1981. Kim
Long ago, I used to be concerned about that too until someone pointed out to me that every semi truck runs in this condition. 80,000# GVW (or 160,000 #'s in Michigan!) but the tractor certainly doesn't weigh half of that. Perhaps Canada has some specific regs around personal or commercial towing. And I'm certainly not a rules and regs expert!
Someone mentioned that today's trucks are more capable than older trucks in towing. Very true! It wasn't very long ago (<20 years ago) that the Big 3 (I worked for one of them but only on engines) were constantly trying to outdo each other every year with upping their towing ratings on their trucks. It got completely out of control until rational thinking prevailed and SAE standards were brought out to determine towing ratings. Braking, cooling, turning, frame stiffness, etc, etc all became part of the equation. That immediately slowed (not stopped) the increases in tow ratings as each company still wanted what they saw as a competitive edge for their trucks. But this time, they truly did add content to the truck to be able to back up their claimed ratings as opposed to just an "I pulled a house for 5 blocks thus I'm capable" kind of thing (or whatever internal directives they used) . In the end, we the customer got a better vehicle with capabilities that can be compared across the brands. :thumbsup:
I've got a 2023 1500 series truck rated at 13,200#'s trailer weight and use it to pull my 24' car hauler enclosed trailer. The towing package on the truck consists of a bunch of big and small things from the transmission, cooling (engine and trans), axle, springs/shocks, braces, brakes, axle ratio, etc, etc. While I have no plans to ever test its full capability, it made multiple trips pulling my car hauler trailer to/from Michigan to Florida when I moved. Other than drinking lots of fuel(!), it did just fine. The heaviest I had it loaded was a tad over 10,000#'s (trailer is rated to 12,000 #'s). I watched the engine and trans temps pulling the grades on I-75 heading to Knoxville, Tennessee, doing 65-70 mph and they never budged. These newer trucks are terrific machines!
408 4sp solid roller and SS springs . Could barely tell it was back there.
No way I would tow something heavier and longer than the car ! Maybe flat tow with a tow bar like mentioned .
Problem will be the Tail wagging the dog .
I used my car to tow when I was very broke. I found early that the towing vehicle needs to be of a longer wheelbase than the trailer wheelbase. a duster wheelbase is WAY too short for that,plus too narrow, and light. I used a 71 New yorker with a 440 engine,or Get a pickup is also suggested
I've got a Plymouth Duster trailer hitch it's still on the duster Factory dealership add-on
