Yes it is easier with a clutch car . Other than a scatter shield and SFI clutch you can run any tranny you want . NMCA has a special class just for Tremec cars .Hopefully my tranny doesn’t explode as I put 3 grand worth of good parts into it. Plus the converter is for nos and a trans brake. I guess I could get a shield but we only race 3-4 times a year. I heard that being my car was a 4 gear that it is easier to install a shield. Idk about that though. Kim
I run a CSR shield on my Dart ( 408 S.B./ 904 ) had to cut a few tabs on the trans case and the top trans bolts are hard to reach, ( I put access holes in the floor to reach ) its also real close to the TTI headers but clears. I believe NHRA rules are 10.99 and quicker but I could be wrong I added mine when the car started going in the Tens as per the rules then. Although I am now going 11.50s I keep it in for safety. I went to a Divisional Open a few years ago although I was running 11.50 index the inspector still asked if I had a trans shield, I said yes I do but told him I only run 11.50s he said " oh yeah ". We ran at a National event back in 2014 and the NHRA tech inspectors never checked for it they probably knew it wasn't required for 11.50s. Keep in mind you also have to have a locking trans dipstick. I have an ATI but its only a locking plug I remove it to check the trans fluid on the regular dipstick then reinsert the plug.I have universal from RCI, it fits OK...long straps, and my headers hit part of it (had to cut a chunk out so I didn't burn them up)....good ole universal fit....one size fits nothing...lol.
thanks for the info , wicked pissa rideI run a CSR shield on my Dart ( 408 S.B./ 904 ) had to cut a few tabs on the trans case and the top trans bolts are hard to reach, ( I put access holes in the floor to reach ) its also real close to the TTI headers but clears. I believe NHRA rules are 10.99 and quicker but I could be wrong I added mine when the car started going in the Tens as per the rules then. Although I am now going 11.50s I keep it in for safety. I went to a Divisional Open a few years ago although I was running 11.50 index the inspector still asked if I had a trans shield, I said yes I do but told him I only run 11.50s he said " oh yeah ". We ran at a National event back in 2014 and the NHRA tech inspectors never checked for it they probably knew it wasn't required for 11.50s. Keep in mind you also have to have a locking trans dipstick. I have an ATI but its only a locking plug I remove it to check the trans fluid on the regular dipstick then reinsert the plug.
