trans and motor mounts?
kielbasavw
orange county
im getting a little ahead of my self, and looking for mounts, i see about the poly mounts which are $120, which to me, is pretty much ridiculous for mounts, i have bought many poly mounts for difference cars and parts, none are that expensive, not even half the amount. also i don't even see a trans mount for a early a body either.
my question is, is there any other alternatives of a good decent mount, and what do i do about the transmission mount.
If it's just a mild street car, I'd just use some stock rubber mounts. For performance use, you may have to save your pennies for the poly stuff. Which year, model, engine, trans, do you have?
Trans mounts are the same in most cases and Trans Dapt sells the mounts at half the cost
of the others TransDapt is with Headman Performance group
HeadmanperformanceGroup.com
If you have pre 1972 I have them brand new in the box as I switched projects
good luck
Happy Holidays!
I have a 65 valiant pm me if you could about your mounts if you'd like, I'm on a phone and hard for me to use this website properly. Thanks
