racerdude5
Will the transmission cooler lines for a 318/904 slide out after I disconnect the ends from the radiator and the trans? Or do I need to take more of the car apart to be able to get them out?
don't forget that there are several anchor point on the bottom of the car where it attaches to the car
good luck,hope you dont have headers.they come out a lot easier,than going in,that is if your installing new ones,bucause not so worried about bending
mhh, ill have to crawl back under there tomorrow and see what in the world im thinking off then
