Transmission 904/727 shifter selector shaft bushings
synchro66
Gold Coast Australia
Does anyone know where i can source the 2 little nylon bushings for the base of the 727/904 auto floor change selector shaft?, as per attached pic. Thanks in advance
They appear to be standard split nylon bushings if you have the measurements try the Industrial Supply Houses like MSC or McMaster Carr - McMaster might have a better selection and their site is easier to use
The "Help" has some of the bushings that I replaced in my linkage. I have a Dorman Help # 14041 which is an assortment of pedal and shift linkage bushings. Most big auto supplies have these.
