[WANTED] Transmission cooler line fittings
GSS
MN
Rating - 0%
0   0   0
Hi Gang,
I need 2 of the brass fittings found on either end of the transmission cooler lines. I believe they are -5 (45*) x 1/8" NPT.
Also need one of the steel compression nuts for 5/16 tubing.
Thanks
You can get from auto parts stores also summit
You must have better parts stores than my local Napa, Autozone, and O'Reilly's.
Summit is out stock (PN BLF-134B) but AGS appears to have them but they don't have the nut as far as I can tell and they haven't picked up the phone or responded to email.
dorman Compression fitting 785-306 Summit # RNB785-306
You should be able to go a good hardware store and purchase a 5/16 copper tubbing compression fitting to splice tubing together. That would give you compression nuts and compression sleeves you need. The radiator and the transmission should be 1/8 NPT with a #5 an type fitting. You might try the section that has fittings for gas lines. They are brass
Summit # AER FBM2513
The Dorman nuts are 1/2"-24 thread. I need 1/2"-20. I guess I failed to mention this is a restoration so the Aeroquip and Earl's stuff is out. Thanks for taking the time. You wouldn't believe the time I have put into trying to find this stuff.
Does the tube nut you show in post 1 thread into one of the radiator fittings in your photo.
If so it is a inverted tube nut, not a compression nut.
