[WANTED] Transmission Cooling Line Bracket
Wholeshot
New Member
Ohio
Rating - 0%
0   0   0
Looking for a nice bracket like the one in the photo. I do not know if the bracket in the photo is from an A body. Even if you do not have a bracket to sell, like the one in the photo, if you know the P/N, or where this bracket was used (body, year, engine/trans), I would appreciateit if you would share that info. Thanks
If this can work, I have this one that I believe is a SB 727 application, 66-70.
Thanks for taking the time to respond to my Wanted Ad. I already have several of the brackets like the one in your photo. In order to use the bracket like your's, I would need to cut it apart,reposition the 2 pieces, do some trimming, and weld the 2 pieces together. If I can find a bracket like the one in my photo, I think all I would need to do would be to make a 90 degree bend in the upper portion of the bracket. Thanks again.
