dartlove
Ok, using motor plate and mid plate. Would you use solid or rubber mount on transmission crossmember
A friend had and raced a low 9 second duster, he had a motor plate w/ a rubber mount , no problems ! I have a motor plate with struts to keep it from forward to rear movement and a rubber trans mount.Al’s old big block Duster had front engine plate and solid trans mount. Never had any issues.
My ride has one of those large polyurethane mounts on it.
