Transmission Recommended to Run Behind Built 360ci Engine in a 63 Valiant
"Also, I am curious if there is anything that I could do so the push button shifter on the dash could still be functional. It's not required, but would be nice."
I think in order to retain the pushbutton shifter you have in the car you will need to find a 1964 V-8 transmission. 65 is cable shifted but has an extra detent in the valve body. If you're willing to go with a different shifter most any 904 will work.
