Tremic 5 speed install list
Kendog 170
Let the boy go !
Reading Ma.
I have a 68 Dart 340 / 4 spd. I want to compile a complete list of parts I would need to do a complete swap. I will do the install myself eventually. I want tally up everything I will need as to start compiling all my parts 1st. Looking for advice from previous installers.
Thanks
I did my GTS, it was a factory 4 speed car too. I retained the factory Zbar system. If you have the 4 speed drive shaft it will work, mine was the large U-joint, I just bought a conversion joint for the TKO. I don't recall the exact one that I used, I'd need to look. My TKO600 is the Ford Version. I reused my McLeod clutch but bought a 26 spline disc. You'll need a speedometer adapter to use the stock cable. Most of the work is going to be redoing the tunnel and hoop. A TKX should lessen this some. I seem to recall flipping the shifter so it was a bit more forward and I used a shifter handle from SST.
I did it to a 71 Cuda already a 4 speed. You need a Bellhousing to adapt the tranny, I got a different trans mount, a speedometer cable and adapter and a clutch disc to match the splines on the transmission. I did the conversion about 20 years ago when Kiesler started making it available as a kit. Initially they made an adapter plate to bolt to the original bellhousing and then eventually made a BH to bolt to the tranny.
depends what you are going to do.
buy a kit
or buy parts and DIY
standard or custom bell housing
manual or hydraulic clutch
which Tremec
some things are common
sleeve the end of the tremec input to 0.75 and buy a roller spigot bearing used on 90s dodge trucks or come up with some kind of custom made version that fits the end of the input shaft in the correct size for a mopar crank torque converter register
the flat faced throwout bearing used on big block a833 and some magnum equipped trucks has the same width of tabs for a standard clutch fork as any other but its bore is bigger so it fits the majority of tremec input bearing retainer tubes
depending on the trans it will take a chevy bullet type speedo drive or a ford type speedo drive you will need a new speedo cable unless you go electronic.
your standard clutch with a different plate will work
tremec shifters, often use flat plate spring shims or washer for stick centering. they are pretty unbreakable, be aware that aftermarket shifters may use the same cross shaft through the main shifter stub, but the cross shaft is pressing on coil springs in small pockets either side instead. The coil springs snap.. avoid....
Look for an aftermarket shifter with belleville spring washers for centering and spherical bearing for support. same tech, same robustness and not crap like all of the rest.
very few of the shifters actually swap over easily, and there are some crazy dimensions for the bolts when you actually measure. What looks like a square or rectangular spacing often isn't.
get a shifter designed for that model, and if it can go two ways onto the housing to move stick position, make sure you have the other parts to fit it the way you need it. The offset lever in the trans may need to be swapped or turned around.
none of the standard tremec IBR flange sizes is the same as a mopar
so if you are buying a bellhousing you are sorted, if you are not. this may help
4.85 inch jeep and TKO
4.905 inch ford T5
4.6875 inch chevy and some UK ford
your tremec will most likely be 4.85
mopar 4.35 4.80 5.125
so taking a tko or jeep sized IBR and getting it cut to 4.80 can facilitate adpater/standard bell housing mounting
speedo gears
If its a ford derived tremec the long ford yoke may be just what you need to retain your current tail shaft
conversion joint necessary
unless its a t5 with an S10 forward shift you are going to have to cut out the front of the tunnel and the cross member hump on an A body
if its an early 3550 or tko 500 with kiesler modifications...
They cut/machined the forward shifter box on the case, down to level with the shift rail. This is an area in front of the shifter box you would use when installing in a mopar. They used a tin plate shim cover, held down by the shifter, making that part lower so you don;t have to take out the crossmember hump.
But an a adapter on a standard bell can then be no more than 1/4 inch for this to work. trans position in the car needs to be spot on, otherwise the back of the trans or the front of the shifter box hits the hump.
The front of the trans above the input centreline is still too tall for the tunnel so a cut n shut is needed, at least on cars with an auto trans tunnel.
gauge plate/ground flat plate, tool steel plate, necessary for adapter, tolerance on standard flat plate is too much in respect to misalignment. 12inch x 12 inch approx $100 in raw material.
TKX dunno.. looks similar to the tko work and fewer options for machining case to get it to fit
custom rear mount in most cases, in order to use an OEM ford or chevy rubber mount.
The foot on the tail housing on most tremec is an inch lower than mopar.
In some chevy application could be at an angle.
Some t5s were lent over 13*?? to fit the wide case-top into a narrow tall tunnel.
Some others had a few degree offset left or right. This may not impact later transmissions but mock up bell and trans on blocks to check.
you might get away with a post 73 mopar spool type mount at an odd angle
your trials and tribulations really depend on which transmission or which tail housing and where you buy it from.
all new and in a kit for your car = easier,
but the guy who sells you the kit doesn't own your car... so he is quite happy to encourage you to chop it up to fit the transmission kit he wants to sell you
Dave
Thanks for the responses.
Good info.
factory 4 spd. Mcleod in it now. Like to use factory z-bar. Large joint driveshaft as well. I'm not rich so I may source a used unit as well. I'll check with Silver Sport to see what they offer as well.
Any links or part #s on Conversion joint, Speedo adapter and other items are also appreciated.
My 71 Cuda had a Hurst stick and bolted right to the tranny. I don't think an adapter was necessary for it. But I guess it depends on what tranny you wind up with. Belhousing was about $300.
yeah bolting on the stick is usually no problem, there is just such a range of quality in the shifter bases that bolt to the transmissions.... i.e the bit you bolt the stick to.
standard = good enough. you can usually make custom nylon collars for the shift rail to act as positive stops rather than the usual aftermarket bolt and nut set up.
the aftermarket ranges from awful to brilliant... aim for brilliant if going aftermarket, look for a shifter base with physical stick centreing that is based like the orginal on curved spring shims or belleville spring washers rather than very short thick-wire coiled springs, which are not very good in this kind of application.
my comment about bolt spacing was for the base onto the shifter box
ford pattern is not rectangular
chevy pattern is wider than ford so you can't easily cut down a ford base
tko and t56 bases have in some cases shorter stubs and the t56 in some case looks like the old chevy size base but its not...
basically buy the right shifter base with decent tech in there for stick centering or use whats is on there from the factory...
Dave
Good info.
I started with a now defunct Hurst kit that Holley bought out, so most of the stuff is available through Holley. The yoke it came with was for a Spicer 1330 so I bought something like this, probably the most heavy duty one I could find. So really it will come down to what transmission yoke you use
https://www.amazon.com/Spicer-5-7437X-U-Joint-Kit/dp/B00DOI8VWO?tag=fabo03-20
If you go aluminum aftermarket bellhousing, I found the one I have needed the 72-up Z bar pivot, the 71-down set the Zbar at an odd angle.
https://www.holley.com/products/drivetrain/bellhousings/mopar/parts/LK7000
https://www.holley.com/products/drivetrain/bellhousings/mopar/parts/LK7000K <--This one is SFI if that matters.
On the speedometer, I looked and couldn't find anything direct, They have to exists because I have one in my car. I seem to recall Mopar and GM are the same thread?
I used this shift handle from Silver Sport, I'm using a console and it work great for me, but I'm 6'2 with long arms. I rotated the shifter 180 degrees on the transmission to be more forward. So this is an area you'll need to play with for your driving ergonomics.
When swapping bellhousings you'll have to check for TIR (total indicator runout) to verify that the BH opening is aligned with the crankshaft. SST requires the test for warranty purposes, and they have a good YT video explaining the process. RobbMc Performance Products has the correct Mopar sized offset dowels if needed.
When I bought my 6 speed swap kit from Silver Sport they provided a complete speedometer cable to hook original speedometer to the Tremec 6 speed. They dont list all the little stuff they sell but if you ask for a quote it will be a line item with price and part number.
If you request a quote from Silver Sport they will provide an itemized list of parts for your specific car.
Thanks. I just submitted for a quote for the TKX Kit, Close ratio .068 5th gear. Their BH in case I decide to go hydraulic.
[Ah you're sorted out already, took me too long to write]
T5 in and out numerous times and still not there...
what i have learned.... Might be of use to someone....
you ask for part numbers gonna be hard to say unless you say which trans :)
If you want to use the standard Z bar set up you will have to use a standard bellhousing or a conversion bellhousing modeled after the standard bellhousing with the z bar stud mount holes in it.
standard bell
Most off the shelf adapters of bell housing to trans are aluminium, light weight easy to mill flat, they are 18-20mm thick to accommodate the offset in size between the input bearing retainer flange and the input bearing retainer register in the bellhousing. This may well push the transmission back further than expected with a bellhousing designed for mopar input shaft length and a transmission with what is usually a shorter input shaft length. basically the whole trans was designed for a bellhousing 6-7 inches deep and the mopar one is deeper than that and has a 3/4 inch adapter on the back.
if you intend to use a concentric slave hydraulic throw out bearing, the adapter needs to cater for the long anti rotation stud, which means it needs a specific half moon machined into its centering boss to allow 1 IBR bolt to be replaced with a long stud
further back may be good from a rear mount and stick position but when you gain in this area you can more or less guarantee that it will also push the speedo drive back into trouble, so that it is now pressed up against or into the torsion bar crossmember, or the remains of it.
You swap one problem for another.
steel adapters can be 6 mm or 1/4 inch thick that could be of more use
trouble is the input bearing retainer flange is only 6mm thick which means you can centre your adapter on the trans perfectly but there is nothing to centre your bellhousing on the adapter.
1/4 inch is deep just enough to accomodate the head of a counter sunk allen drive unbrako bolt.
2 options
1) get an adapter ring made up that is 12mm tall, bore your adapter plate the size of the IBR+the wall thickness of your adapter ring. Bore the bell to the size of the adapter ring. everything centred on the adapter ring
2) put the IBR onto the trans but space it forward with flat washers, just enough to make it stand proud of your flat plate adapter when bolted to trans But not so far that the contour in its rear side that centres it into the transmission is not engaged. centre bell,drill tap, and counter sunk unbrako bolt on the adapter. remove the lot from the trans and refit the IBR properly
problems with option 1 standard bell could potentially not have enough meat to accommodate the bore you need. you will cut into the clutch fork mounting pad bolt area and possibly breach the roof of the bellhousing at the top edge. more of a problem with low/squarish patten bells like a 3 speed slant 6 one
problems with option 2 its not very accurate and depending on trans the register for the IBR in the front of the trans and the lump on the back of the IBR around the shaft my not be deep enough to sit the IBR out far enough to make a good attempt at centering.
Adapter Method
mock up trans and bell on blocks behind motor with flywheel in position
put clutch plate on spline the right way round
move trans towards flywheel, so that the start of the taper-down from the spline to the spigot end of the input shaft aligns with the flat clutch face of the flywheel
push clutch up to flywheel and mark input shaft to show where it sits
pull trans out and check that when you put the clutch plate where you marked that its boss is engaged for full length with spline, all as near as damn it.
put it all back, in same position without clutch plate, check the engagement of the end of the input with either the in-crank bush or the area where the roller spigot would go
if the end is in the right place make your decision about input shaft support, Bush or roller.
now is the time to cut down the IBR tube if it is too long to fit your clutch plate. you need space between clutch boss and end of IBR tube so the clutch can disengage. it will drag if there is no space
the spigot end will be too small.
choice: make it standard mopar size of 0.75 inch with a shrink fit hard steel sleeve, take input shaft to machine shop and say "make it happen" or get a bush or roller spigot that fits the spigot end, and work out how to machine or custom fit to crank or converter register.
measure gap between bellhousing back and trans to work out how thick your adapter should be. less than 6mm? it needs to be 6mm+ for the bolts. More than 6mm ok.... don't go too far or just buy an ally adapter and work out any issues.
Then you need to check that the trans and the bellhousing do not try to share the same physical space for their bolts. if they do you need to re place problem bolt between adapter and bellhousing with 2 on a smaller diameter, distance out from centre line, into the back of the bellhousing
Clutch stuff
Need a plate that fits the spline that is the same size and quality as you mopar plate, you need just enough clutch, not some lock up loonacy that will smash up you new transmission.
Need an throwout bearing that fits the IBR tube size
Need a throw out bearing on a throw out bearing carrier of a correct height that fits between the clutch cover fingers and the base of the IBR tube, you need a pretty flat IBR for manual clutch not one with a pedestal for a hydraulic concentric cylinder.
and of course it needs to fit the clutch fork, so buy a mopar one for mopar fork or ford one for ford derived fork.
Fork will be just short of front of clutch fork window if you have this right. expect a fight to put on the fork boot (mopar)
OR
if it is a ford transmission and you have a ford style ball stud mount for the fork in the bell, (passenger side) and you have a ford style clutch fork, IBR tube passes through its middle. it sticks out the drivers side and you push it forward to disengage the clutch, and you have a ford style throwout bearing, and you have a Tremec transmission designed for a ford it may well have mounting tabs for a ford style push forward external hydraulic clutch slave. all the ford parts in a ford style bellhousing will work provided you have enough adjustment on your slave cylinder rod, to take up the slack in a bellhousing that may be longer than a ford style housing.
Speedo
the square centre cable in a chevy speedo cable fits a mopar screw ferrule speedo head and the top end thread is the same. the bottom end is a chevy bullet and massive threaded end
conversion of a electronic only trans to mechanical drive.
electronic speedo holes point directly at the output shaft
mechanical drive speedo holes point under or over the output shaft
chevy drive holes have a flat base at the far end
ford drive holes have a pofiled base at the other end dip in the middle.
you can't mix n match.
if it was an electronic speedo OEM Trans, the output shaft won't necessarily have the lump on it for the mechanical gear or it won't be in the right place for your mechanical drive tail housing. or it won't be drilled for the retainer clip. iti s hardened steel so drilling it is a shop job.
as is welding up and re boring a tail housing to convert to mechanical drive speedo use, if one doesn't exist and you really want mechanical drive its an expensive option if you need someone else to do the tig welding and machining.
if you need a hump for the gear in a new position, Aluminium tube honed to the exact diameter of your output shaft, and lathed down on the outside Diameter to fit your speedo gear bore
split it and clamp on with a split collar, loktite the allen bolts, then drilled for the retaining clip, That works.
This potentially only a problem on second hand OEM transmissions.
electronic to manual drive boxes $400+
manual to electronic conversions chevy and jeep and ford standard parts, mechanical drive 3 wire pulse generators were a thing for ABS Tachos and ECU for about 10 minutes in the the 1990s while the transmissions went through a crossover to electronic speedo set ups
Rear cross member mounts
Hurst holley, if you got it in the end of line sale, chop it up as necessary the tabs and cross bar are useful if you are not welding that odd shaped part it into a cut up car.
US car tool mount, looks useful, will have to wait until they build one for you.
SST mount not so sure you can buy them outside of the kit.
flat tube across the car bolted to you chassis connectors...works but looks rubbish
post 73 spool mount can be cut n shut to put the spool mount in a different place but the spool mount mounting to trans rear foot bolt spacing is wrong. re drill trans and stud it.
stick
ideally position level with bottom of wheel fore/aft.
ideally positioned about level with bottom of wheel up down
ideally positioned so that its far away position and its closest position do not hit dash seat steering wheel or passenger
this is like 8 to 10 inches away from wheel rim when in neutral. short stick = smaller movements
long stick like stirring soup. need stronger reaction/centering springs in the shifter base
truck sticks are long, truck sticks often have a nice bend, truck stick bases have stronger springs and a much shorter gate due to use with a long stick. truck stick set up when cut down makes for a quick shift setup when used in a car, big reduction in throw.
all tremec Knocking the stick forward from 2nd with no other input should land it directly in 3rd via the centering/reaction springs if it doesn't the stick is too long for the reaction/centreing set up in your shifter base or vice versa namely not enough spring for your big stick... or the springs are broken or badly adjusted
Space.
smallest tremec is the t5
the top edge/cover edge presses against the tunnel on the US drivers side in a auto tunnel car, the front of the trans has space. the shift rail on a T5 sits 1 inch above the output shaft absolutely level with the shifter box top edge meaning it would need to pass directly through the torsion bar crossmember in the top of the tunnel with the trans in the correct place and the shifter box level with the tunnel opening.
All single rail transmissions have this problem unless the rail is kinked down as per australian fitment of borg warner single rail 4 speeds. that used a linkage that hugged the output shaft tunnel of the housing i.e 1 inch lower
Or you use a transmission with a tail housing and stick position designed for a bench seat truck, A front shift.
all other tremec boxes are bigger/taller/wider
output/tail housing bushes can be replaced but i have been lead to believe the orginal was installed and aligned using a special jig. if it doesn't need replacing leave well alone
head is now empty and i need a lie down
Dave
I just finished this swap on my 72 Duster. I sourced all the parts, and did all the work myself. The car drives flawlessly with the Tremec trans & 3.91 gears. I used a new but old school Tremec 3550, Lakewood conversion bell housing, Silver Sport supplied a direct fit speedo cable. I also used the original Z-bar setup.
And so it begins,,,,,, 5-speed Duster swap!
I too just finished a swap, A833 to A833 OD.
Cost me $1,300, it runs 2,200rpm @75mph, just drove it 2,500 miles.
