Trick Flow Head dimensions compared to Stock Iron Head dimension
RKT
Member
We are planning to use the Trick Flow heads on our low deck 400 in our early a-body. I may have a clearance issue between the master cylinder & valve cover using Trick Flow heads. Currently we are running stock iron heads with no clearance issues. In an effort to add additional clearance between the valve cover and master cylinder we will be using the Wilwood master cylinder along with the firewall relocation adapter plate. This will move the master cylinder over 7/8". I am hoping someone can tell me the Trick Flow head dimensions compared to Stock Iron head dimension. Unfortunately I do not have a set of Trick Flow heads to test fit. They cost a bit to much to just do a test fit.
Thanks for any and all imput.
Yes, I contacted Trick Flow. They are sending me the spec sheet from their engineering group. I'll post the info once I receive. Thanks
The TF heads are about 5/8 of an inch taller than cast iron heads. You can run short valve covers if you have a space problem. I'm using billet covers which are only 3 inches tall on my TF heads.
You shouldn't have any problems with clearance, especially with a B block and the offset adaptor. I'm running an RB and had no problems with Indy EZ heads or Indy 572-13 heads. And both of those heads are much taller than the stock heads.
I appreciate the info. Thank you
