mullinax95
I just install a new Auto Meter tach that I got from Summit for my car and I can't get it to work. The light comes on, the tach needle zeros out when I cut the switch on, but after I start the car the tach needle sits there. I've connected the signal wire to the negative side of the coil and to the Accel ignition box tach wire and neither one do I get a response. I've pulled out the ohm meter and checked everything.
Auto Meter tech, and Summit tech are closed on Saturdays and Sundays so what do you guys think it could be?
