Pretty new. Nope, no carb explosions ever through this carb. The screws on the float bowls sides are all the way in right now.What happens if you close the idle mixture screws all the way? While it's running of course. Did you have a backfire or pop through the carb right around the time this started happening? How old is your carb?
Ok, so the idle screws are all the way in right now, and it still runs, am I reading this correctly? It looks like you've got a bad power valve buddy, your engine should die from fuel starvation when the idle screws are bottomed out.
This is absoluetly wonderful...thats kind of what i getting LOL ...exactly ^^^
Its not a blue gasket, I can tell you that, but it has one.If it is a bad power valve, it would be a very easy and inexpensive fix.
Can you hook me up with a link to the gaskets and power valve from O'reilly? Cause I don't wanna get the wrong ****:???:. why the 8.5?Well, first you'll need a power valve. Most Oreilly Auto parts stores carry power valves and gaskets in stock. You'll need both float bowl and metering block gaskets (buy the reuseable blue ones), and your carb probably came with either a 6.5 or 8.5 power valve. Get an 8.5 if you can, but to get you back on the road a 6.5 will do.
To swap it out you'll first need to disconnect the fuel line from the front float bowl. Then remove the bowl and metering block (the metering block may be stuck to the main body but it will pull off, the gasket is holding it). The power valve will be screwed into the block, you'll see it. Simply unscrew the the power valve, clean all the gasket material off, then blow everything out with carb cleaner to be sure. After that all you need to do is install the new power valve, new gaskets, and put it all back together. A trick for the gaskets is to spray them with wd-40 when installing them. That way they don't stick as much if you take the bowls off again.
Once you get it all together, set the idle screws to 1.5 turns out from bottomed out as a starting point. Start it up and go. Easy peasy, it'll cost you ~$25.
Oh, one more thing. Make sure the accelerator pump arm put back correctly when putting the float bowl back on.
\This is the store I searched, hope it's your local store. According to their site everything is in stock.
4300 Buford Drive Ste 1a - Buford, GA
(770) 945-7203
Power Valve
http://www.oreillyauto.com/site/c/d...er+valves_-1_1276&keyword=holley+power+valves
Float Gaskets
http://www.oreillyauto.com/site/c/d...276&keyword=holley+gaskets&pt=N1043&ppt=C0261
Metering Block Gasket
http://www.oreillyauto.com/site/c/d...276&keyword=holley+gaskets&pt=N1044&ppt=C0261
Ok, closer to ~$35, but still not too bad.
The reason for the 8.5 power valve is because it will fit your engine better (stock cam right?). The 6.5 and 8.5 numbers refer to the vacuum reading the power valve will open. It all depends on the vacuum your engine produces at idle, in gear. A general rule of thumb is 1/2 the vacuum for your power valve, so if your engine makes 17" vacuum, then an 8.5 power valve would be recommended. You can even go higher, like a 10.5, but that's a story for another time, but for now don't worry about it. A 6.5 pv will get you back on the road.
yep, my store don't got itNo, it's the same price, just usually not in stock in most stores.
worth a shot. The only way I have it not stalling right now is with the idle up more. like too high.Hey I was thinking this morning. Before tearing your carb apart, try turning the idle screws out 1.5 turns and see what that does. That may fix it right there. It may be too lean instead of rich.
