I do not see a truck section but I am sure some of you guys play around with trucks as well.
I bought a 73 D-100, front fenders are not in the greatest shape, beat up and a small spot of cancer coming thru on the drivers lower.
I have a pristine 1986 front end.
Someone told me on another forum that I could swap the sheetmetal no issue. I am a bodyman, I have taken some quick measurements with my tram gauge and things arent looking good.
I know the cabs must be close cause I put an early powerwagon hood on my 86 W-100 recently and only had to relocate the latch assy so hood/cowl grille assy is the same span across the front but rad support definitely does not bolt on in the same way.
Anyway without getting more long winded anyone here tried swapping over the sheetmetal?
