Trun Signal Switching Diagram
dustymopar
Essex, UK
Hi, Having problems with my Indictaor lights here - left hand Front does not illuminate, and left hand rear does but does not flash. Right hand work perfectly.
Does anyone out there have a diagram showing the switching of the Turn signal switch (71 A Body)
Thanks
to be 100% honest. it really does sound like you have a burned out bulb. i think the way it works is if it doesn't blink it is telling you that you have a burned out bulb. it was the way they did it back in the day so you know you had a problem. that is why the right side works fine and the left side doesn't. change the bulb in the left front and you should be good to go.
Have you replaced any pig tails. Compare wire colours left side to right. Usually brown is park yellow is left signal and green is right signal. Black usually ground.
turn on your emergency flashers and check the lights this usually overrides everything if the flashers work, it may be in the switch if not, check the bulb, socket, and the connectors
