[WANTED] Trunk floor extensions 71 Duster
Just some advice, stay away from the cheap trunk extensions. In my experience they dont fit at all and the time you spend trying to make them fit will make you wish you had spent more for the AMD ones.
Problem is right now most of the sheet metal is slim pickings. I bet you half of AMD's stuff is out of stock.
The next best thing to AMD would be some original donors but its going to be tough finding good used trunk extensions.
Thanks MoparMike1974 I was hoping someone would have a set laying around they did not need. I did order the trunk pan from AMD thinking I could salvage my dropdowns but could not.
It sucks, AMD is out of stock of alot of stuff right now. I have a huge order to put in but half of its out of stock.
