Trunk light location
kiss
San Diego, CA
Can someone take a pic to show me where the trunk light is located? I need to install mine on my 71 Dart and I can't recall where it mounts. I know the switch mounts to the piece in the upper-right side corner of the trunk. Pics of where to route the wiring would be helpful also. Thanks.
You can kind of see the light in this pic.
You should see the holes for the switch just to the left of the hinge under that corner.
Thanks but does anyone have any other pics? I just looked around and can't find anything.
Here you go. The switch is easy, pretty obvious. The light itself is harder, it's mounted to the underside of the dutchman on a support brace. The brace runs between the speaker hole and the cut out for the rear defrost option on the driver's side, you can see the most landmarks in the second picture.
