hemichuck
i have this 408 that I have been building out of junk I've been digging out of my garage, I've come down to choosing between this Comp cams Hydraulic, CRS 305H10 which is 525 lift 305 duration 110 centerline, duration @050 is 253. Or the Mopar Performance 557 lift solid cam which is 296 duration and 110 centerline. Here are the specs on the rest of the engine, 360 block .030 over with flat top Probe Pistons with valve notches, zero deck. 4 inch stroke, Edelbrock heads with 63cc chambers, roller rockers, Holley Strip Dominator intake with at least a 750 double pumper. The motor will be in a Valiant and I can run 4 speed or Automatic either one and will probably run a gear around 4.30.
