trying to turbo my demon
zereo0311
New Member
morgan hill
Hi,
Trying to turbo charge my 72' Demon, but I don't have the tools of the time to build my own single-turbo headers. I was hoping somebody could point me in the right direction, to where i may find a pair. I'm running a small block 360 and am building it for autocross. Any help would be appreciated :banghead:
One of the tricks is to run pipe under the engine to the opposite side and mount the turbos. Another trick is to put the exhaust manifolds on back wards and tap the flange in the front. If you had a big block, you could mount the manifolds up side down. Building a manifold could be simple. Take an old header and a piece of diesel sized exhaust pipe (like 5-6"). Cut the primaries about 1-1.5" from the flange. Drill holes in the diesel pipe to mate up to your primary pipes and weld them in place. Run a short piece of pipe from the diesel pipe to where you want to mount the turbo. Weld caps in the ends and VIOLA!!
Mike
