TTI system interfere w/ e-brake cable?
cuda440paul
Looking at TTI's dual exhaust system for a '65 Valiant. It has a footnote stating the emergency-brake bracket has to be removed. Anybody use this system? Will the stock emergency brake cables work?
Well I just received a set & will be working on it next. I plan to cut the emergency brake cable bracket and let my cables lay over the pipes - I never use it anyways and it will still be connected. You could convert to a later cable routing with the cables splitting by the left spring and the right side going over the axle.
Also have to shorten the 90 degree oil filter mount bolt head.
Interesting. Mine is a 4-speed so really need the brake. So can the bracket be moved? Really would like to know how this turns out / see pics if possible...
