TTi Z bar help!
bballfan1
ny
So I have TTI headers and bought their small block Z bar. It was hitting header so thought I would bend it away from header. Put in mini starter just to see and it hits both? Help please .
I had this issue come in and it was the wrong bracket on the bell for the z-bar. there was an early 72 ball on an 68-71 bell. they can be interchanged but it put the Z-bar at the wrong place and lowered it, The 68- 71 style the holes in the bell are directly on top of on another. The 72 bell the top hole is rearward from the lower hole. Just something you may want to look at? If you have a 72 ball on a 68-71 bell it will lower it.
68-71
72 and up
Years ago I had the same issue except with a Brewers Z Bar.
