I'm running my car about 5" taller than stock, in way out of adjustment with stock a-arms & offset bushings flipped opposite for increased caster & I'm still way negative. I have to have adjustable.
Those do look nice with gussets around the ball joint but they just won't work.
I went back and looked at your build thread to take a look at the ride height you're running. While I'm not sure you're anywhere near 5" over stock with the suspension, I see why you have issues. You have to be bottomed out on the bump stops or close to it. Honestly, I don't think you're going to have much luck finding a non-custom UCA to work for you.
Pretty much all of the UCA's on the market are designed for cars that are at stock ride height or lower. That's how they build in the geometry. On top of that, lowering these cars actually
improves a lot of the geometry if you're going to an alignment for radial tires, so really the caster is the only thing you have to worry about. Raising the car like you've done definitely changes the geometry, but it's for the worse, not better. And it's not in a way that the tubular UCA's on the market are designed to fix. Just using a UCA with heims won't be a sure fix for that either. The heims are only designed for so much adjustability. You can only run that rear heim in until if bottoms out, and the front heim can only go out until you're reached the minimum number of threads left inside the UCA. I'm not sure that just buying adjustable arms will be enough to fully correct that geometry, it's not like they're infinitely adjustable. They're only designed for a certain range, and at their maximum they'll be adding a good amount of misalignment on those heims, so, you'll see faster wear.
Usually the offset bushings are good enough to get you to +3* or so of caster and a reasonable ride height. The non-adjustable tubular arms can be good for up to near +5* in most situations. And now let me tell you that I run the Hotchkis UCA's on my Challenger, and even with a fair amount of adjustment on a lowered car I'm only at +5* on that car as well. Now, that is an E-body and they are a little different, but realize that even the adjustable arms aren't designed to give you +10* caster. They're good for a couple more degrees, but thats about it.
If you're "way negative" with offset bushings, you may not do a lot better even with adjustable UCA's. That car needs to be lowered some or it will probably take custom made parts to put the right alignment on it.
