Spray with simple green and let it sit overnight. scrape or power wash off next day or however long you can wait. Id keep it moist if your letting it sit for longer than a day. Give it a 'shot' and let us know. My friend bought a 66 Comet and the idiot PO newly sprayed the under body (prpbably to cover a bunch of rust) and half his driveshaft with the stuff! Totally unbalanced the driveshaft. He finally drove it to a driveline shop, removed the driveshaft in the parking lot and watched the guy run it on his lathe and use a chisel on it like he was shaping a wooden table leg on a lathe. Took all the undercoat off the shaft, 2 new U-joints and a balance weight and he was back on the road. It got alot worse when the U-joints started to go, said it was barely noticeable when he bought it.
