mopar56
anyone ever mount a factory " tuff wheel" with matching factory adapter on a tilt column?, this isn't a A body it's actually a wheel and adapter from a " lil red" express (79) going onto a 1980 1/2 ton Dodge, sorry I know this is a A body site and I did post this on the truck site associated with this site but c'mon you guy's are smart!, here is the problem...the splines are good but the hub behind the wheel dosnt seem to go down far enough to contact the horn plunger to make it work and also the old wheel had a "c" collar on the back of the wheel to cancel the signal and the tuff wheel adapter has a wire tab AND it also dos'nt go far enough down to contact the actuating plate for the signal I used this same set up from a Warlock and put it on my sons Duster no problem but the Duster didn't have tilt, thanks for the help
